ECM not working help me
Old May 16, 2003 | 09:26 AM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
I have 86 Z28 TPI. A while back my car caught on fire(wiring problem). I got a wiring harness from the Junkyard and ECM from some guy. Yesterday I installed the wiring and ECM and I think I conected'em right. I tried to start my car up and the engine began to rotate but did not run. My check engine light did not come on (bulb is fine) meaning my ECM is not working. I checked the power inlet at the ECM conector and it had power. Then I tried to bypass the ground and I noticed my RPM needle was going up and down about 200 rpm everytime I grounded the circut.
How do I check the ECM ? Where is my problem?
is it
1 ecm
2 conectors
3 me :lala:
4 other
Thanks,
Ivan
Old May 17, 2003 | 10:49 AM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Anyone have a clue as to what is wrong? Any ideas?
specialized
Jun 18, 2022 09:26 AM
355tpipickup
Aug 19, 2015 10:02 PM
stalkier
Aug 13, 2015 12:59 PM
marcusaw
Aug 10, 2015 08:13 AM
