Stealth Ram Rail-Mount Fuel Pressure Gauge?
Old May 15, 2003 | 07:41 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
What are you guys with Stealth Rams running for a rail-mount fuel pressure gauge? I'd really like to run an autometer ultra-lite 2 1/16" gauge, but I'm not sure what fittings I'll need to hook it up. What size and thread is the port on the stealth ram rail? Would any of the adapters from http://www.anplumbing.com/shop/shop1...auge!_Adapters Adapters work for me?
Old May 15, 2003 | 08:26 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
The hole in the rail where the schrader valve is 1/8 NPT.
Old May 15, 2003 | 09:01 PM
Scott_92RS's Avatar
Car: 1992 RS
Thanks! I just checked out your website and saw your Spohn Tranny crossmember, and it sure looks like you've got studs in there. How'd ya pull that off, I want to it too!
Scott
Old May 16, 2003 | 07:14 AM
Ricktpi's Avatar
Easy. 1/2" wheel studs fished in from the top. A must after the factory holes were stripped out.
Old May 16, 2003 | 07:24 AM
Scott_92RS's Avatar
Car: 1992 RS
By "fished in", you mean you drilled out the holes to 1/2", manuvered the stud to drop though the hole, and just tighetned it down until the knurl pressed into the nut inside the frame rail? Sounds like a pain in the ***, but so is dealing with the crap-*** stripped out bolt holes there... Any particular size wheel stud? Thanks!
Old May 16, 2003 | 07:57 AM
Ricktpi's Avatar
Buy your studs first, then drill the hole out slightly smaller than the knurled shoulder of the stud. I used a coat hanger bent into a sheppards hook to loosly hold the stud. Fish it in through the oval hole in front of the studs, drop it down in the hole, push the hook forward to release, pull stud down with your fingers & thread the nut on. Tighten the nut to seat the stud. It really was not hard. Did the whole job in about 45 mins.
Old May 16, 2003 | 08:22 AM
Scott_92RS's Avatar
Car: 1992 RS
What I want to know is why havent I seen more people do this? Stripping those threads out seems to have happened to just about anyone who has removed the tranny crossmember and tried to reinstall it. Thanks for the info!
Old May 16, 2003 | 08:29 AM
Ricktpi's Avatar
I dunno. The idea came to me one night while lying in bed trying to go to sleep.
Old May 16, 2003 | 11:31 AM
Scott_92RS's Avatar
Car: 1992 RS
How long are the studs you used? I've been searching the net and it looks like a pretty standard length is around 3 inches. That just seems really long, especially if I'm going to have to fish it in there blind.
Old May 17, 2003 | 01:22 PM
Ricktpi's Avatar
I went to NAPA & looked through their catalog. I found some about 2" long.
9192camaro
16
Feb 3, 2019 12:21 AM
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
L98GTA87
Aug 11, 2015 06:55 PM
