T56 conversion with hawks mount. What bushing
Old Mar 2, 2014 | 09:45 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
I'm putting in a 5.3 with a T56. I'm using a Hawks crossmember. My question is do I use energy suspension trans mount for the car I have or the car the trans came from??
89 trans am
I'm getting 3 different numbers.
3-1158
3-1142
3-1108
Old Mar 2, 2014 | 11:12 PM
JacobIroc's Avatar
Car: 92 RS 25th Anniversary
Engine: 305 TBI -> 305 TPI
Transmission: T5/T56
Axle/Gears: 3.08 - 3.73+ soon
Re: T56 conversion with hawks mount. What bushing
If you're talking about the mount that goes between the tailhousing and crossmember, I used the t5 one. And it's worked fine so far.
Old Mar 4, 2014 | 06:46 PM
So then the one for the my thirdgen
Old Mar 7, 2014 | 10:08 AM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
iirc the bushing is the same from 82-02.i bought a poly mount when i did my t56 swap the years ago.i think its a universal mount for 700r4 and works with t5 and t56.it had 3 different bolt hole locations depending on the trans.ive been using mine for yers..no issue,no squeaks and the trans feels firm.the oem rubber ones had too much play for my liking and didnt last as long in my experience.
http://www.hawksthirdgenparts.com/pr...uspension.html
camaro1185
Oct 26, 2015 06:51 AM
topteam54
Oct 6, 2015 12:21 AM
el_muerte
Sep 16, 2015 12:01 AM
mygta87
Sep 14, 2015 10:36 PM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
