driveshaft length with Hawks motor mounts
Car: 1986 IROC-Z
Engine: LS1-ish
Transmission: T56 stage II
Axle/Gears: S60 4:10's
I am pretty sure I know the answer but need confirmation. I just ordered an S60 and they are asking for confirmation of driveshaft length. Im running an LS1/T56 and I'm pretty sure its going to be stock 4th gen length from what I've read but can't find a good answer and need to let them know asap... I'm using Hawks motor mounts and believe they are setback, which should make the driveshaft stock length right? Thanks!
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: driveshaft length with Hawks motor mounts
Not really sure about the motor mounts, but I just went through installing an s60. Easiest way is to just get under the car and measure the new length needed and compare to yours.
Car: 1986 IROC-Z
Engine: LS1-ish
Yeah problem is my car is an empty shell at the moment... think I'll just put the driveshaft on hold for now.
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
i would definitely wait until you have everything in the car and then go from there.
Car: 1986 IROC-Z
Engine: LS1-ish
ambainb
Apr 25, 2016 09:21 PM
NBrehm
Aug 5, 2015 07:57 PM
