Slow start to ls1 swap.
Old Apr 4, 2014 | 09:53 AM
turbota82's Avatar
Car: 1989 Formula
Engine: l98
I will finally start pulling my old l98/700r from my 92 formula next week, cleaning the engine bay and notching the k-member. I will try to post pics on it all. I've had the engine for awhile its from a 2001 ws6 so it should have the z06 intake right? So I want to do a head and cam swap if money allows it we will talk about that later. I still need to buy lots of swap parts I guess close to 1000.00 dollars in all so I'll keep you guys posted thanks. Turbota82
Old Apr 4, 2014 | 05:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
LS6, yes.
Old Apr 4, 2014 | 06:33 PM
coptzer's Avatar
Car: 1986 IROC-Z
Engine: LS1-ish
Transmission: T56 stage II
Axle/Gears: S60 4:10's
Re: Slow start to ls1 swap.
Be prepared to spend more than you budget for, especially for a heads and cam swap. There are things you are going to want to do, or should do once you break the motor apart. My advice is to shop around, it adds up fast. There are good deals to be had if you're not in a super hurry. Take your time and have fun.
Good luck!
Old Apr 6, 2014 | 10:53 PM
dprest68's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
Need pics!
Old Apr 7, 2014 | 07:22 AM
johnw999's Avatar
It's about time for me to pull my engine as well. My LC9 engine and T56 are in the garage and almost ready. I've slowly been gathering the parts as deals come up. I swapped the cam and valve springs. Texas Speed and Performance was the most helpful when I was asking around for cam advice, so I used theirs.
When you pulled your engine, did you remove the hood? I want to remove my engine from above. Then I want to install the new engine from below once I clean up the engine bay.
Old Apr 7, 2014 | 10:35 AM
dprest68's Avatar
Engine: cammed LS1
Regardless of which way you remove the engine, I would definitely remove the hood. It just makes it so much easier to work on everything without the hood in the way. Good luck with it.
Old Apr 7, 2014 | 01:27 PM
coptzer's Avatar
Car: 1986 IROC-Z
Engine: LS1-ish
I removed the hood....
along with a few other parts...
Old Apr 7, 2014 | 01:36 PM
Javier87z28's Avatar
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
Subscribed! Any pics?
Old Apr 7, 2014 | 02:29 PM
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
Mine looked like that at one point.
Old Apr 8, 2014 | 06:11 PM
five7kid's Avatar
If you drop the engine/trans out the bottom, removing the hood is just extra work.
Old Apr 10, 2014 | 03:10 AM
91z28 98ta's Avatar
Car: 89 iroc 98 T/A
Engine: LSX
Good luck with the budget mine blew way over limit quick and I'm not really even close to done.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
NBrehm
Aug 25, 2015 11:49 PM
sreZ28
Aug 14, 2015 07:48 PM
86Base
Aug 8, 2015 01:34 PM
