lq4 swap questions
Old Apr 18, 2014 | 10:20 PM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
lq4 swap questions
2006 LQ4.
I have no clue what direction I will fully go, but looking to do 11.50s or faster.
All what sensors to keep
Whats the cheapest accessories drive to get (no ac)
Can I use a corvette oil pan (umi k member)
I hear about the flexplate uses a spacer can I just use any ls flywheel.
Will the stock starter work with the t56.
Will it be cheaper to buy a P&P aftermarket harness and self tuning pcm (I have no cheap source)
Can a turbo from a 96 3500 6.4l diesel work or too small.
Old Apr 21, 2014 | 05:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by Sojer
2006 LQ4.
Front O2s, TPS (in the throttle body), MAP, crank & cam, CTS, MAF (some tune that out of the system), IAT.
Used.
Maybe, but I've never heard of it being done. I would think the wings would interfere with the f-body A-arms, but I don't know that for a fact.
Only need a spacer if running a 4L80E or a pre-LS transmission.
Stock LS1 starter with a LS T56 flywheel. LQ4 starter won't work.
Cheapest will always be a factory harness you modify yourself.
No clue. You'll have to inquire of the PA crowd.
Old Apr 21, 2014 | 07:25 PM
Sojer's Avatar
Re: lq4 swap questions
57kid u the man, I'm picking up my lq4 2 morrow.
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
