91 camaro ls1 header install question
Old May 8, 2014 | 10:20 AM
91 camaro 383's Avatar
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
Im currently doin an ls1 swap into my 91 camaro it has the spohn kmember and deleted hvac i wont be getting my headers for another couple of weeks is it possible to install the hawks long tubes after the motor and trans are in the car oh im using a th400 trans and spohn crossmember
Thanks in advance for the help!
Old May 8, 2014 | 01:12 PM
Pocket's Avatar
Car: 91 Trans Am
Re: 91 camaro ls1 header install question
Yes. Remove the coils and plugs and they slide in extremely easy. One from above, one from below IIRC
Far cry from the all day battle to install LTs on a SBC in a 3rd gen. Plug access is a piece of cake too. Gap, install, replace coils is a 30 min job, even taking a pepsi break
BTW, youll need to cut off the "ears" on the TH400 BH if you havent already
Old May 9, 2014 | 10:44 AM
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
Awesome thanks a lot for the information! Now i can get to the install! I appreciate it!
Old May 9, 2014 | 06:25 PM
Gregs_GSXR's Avatar
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
I actually got mine installed from the top on both sides. Starter removed on the passenger side though
Old May 9, 2014 | 10:18 PM
Pocket's Avatar
Car: 91 Trans Am
Also, if anyone searches this thread, forget all the easy install part when using a scattershield
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
