ls1 harness help
Old Jun 22, 2014 | 08:28 PM
players 91's Avatar
ls1 harness help
im in the process of building my swap harness.i have all sensors wired, all pcm wires labeled by the 411 pin out. im thinking the pcm should have keyed 12v, constant 12v, and ground. blue 1& 40 & red 1 & 40 are ground & blue 20 & 57 are battery +. are these grounds just chassis grounds? are battery + going to or coming from the pcm. what pin is keyed 12v? any help would be great.
Old Jun 24, 2014 | 08:09 PM
Tehsocks's Avatar
Car: 85 Camaro Z28
Engine: 6.0L LS
Transmission: T56 Magnum
Re: ls1 harness help
All 4 grounds goto the chassis ground (in the factory harness, they all get spliced into the same wire)
Blue 20 and 57 are Battery + voltage.
Blue 19 is Ignition voltage (Key on)
This is an excellent source for wiring diagrams.
Good luck!
http://lt1swap.com/2001_ls1_schematic.htm
Old Jun 25, 2014 | 07:12 AM
players 91's Avatar
Thanks for the reply. I was thinking that after reading the updated harness thread but wasn't sure. Don't have much luck when guessing.
Old Jun 25, 2014 | 08:21 AM
WTR388's Avatar
Car: 87 Trans Am
This may help you out a bit too:
https://www.thirdgen.org/forums/ltx-...s1-pinout.html
I enjoyed doing my harness actually.
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
dbrochard
Sep 19, 2015 08:13 PM
gczj13
Sep 18, 2015 01:09 PM
timonator
Sep 17, 2015 06:57 PM
Billy Decker
Sep 4, 2015 03:46 PM
