Help me remember
Old Oct 29, 2014 | 06:50 PM
jay7199's Avatar
Help me remember
I have a 5.3 with 98 ECU swapped into a 89 Firebird, I rebuilt the wiring harness because it was ugly and i have forgotten where pin F from the c207 goes.
Based on some notes from pocket I found whats listed below, how ever PCM fuse confuses me, I clearly have a ECU pin attached to the wire coming from pin F. all the other wires on the C207 are correctly wired.
Anyone know where on a 98 ECU i might have had this pinned?
A Not used
B INJ 1
C MIL
D Fan fuse
E Not used
F PCM Fuse
G INJ 2 fuse
H Not used
J Not used
K Speedo (remember to bypass the buffer box
L Not used
M Cluster GRD
N Not used
P Not used
R Not used
Old Oct 30, 2014 | 08:20 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Help me remember
ECU and ECM are synonymous, sometimes mixed with PCM. In a more literal meaning, the first two control only the engine function and the later also controls electronic automatic transmissions. From a computer fuse perspective, its makes no difference
C207 F goes to the computer IGN/12v switched pin(s), not battery or constant 12v. Instead, those join up with the fuel pump relay 12v in the external 20A fuse holder near the battery
For 97-98 PCMs, the IGN pin is B19 same as 99-03. One of the few pins that dont move
http://lt1swap.com/1998_ls1_pcm_pinouts.htm
Old Oct 31, 2014 | 03:38 AM
jay7199's Avatar
Thanks pocket!
Ed1LE
Sep 30, 2018 09:14 AM
bjpotter
Oct 4, 2015 07:48 PM
Zell1luk
Sep 29, 2015 10:36 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
