info please
Old Dec 7, 2014 | 07:36 AM
lilrobo's Avatar
info please
newbe here guys
dont know if i am in the right spot but here it goes
i did a 5.3 motor swap in my 1955 , i bought a 5.7 motor from a 2002 camaro that had a thrown rod , i want to swap the intake , i havd did a lot of searching and it can be done , i am wondering about the steam line can i use my truck ? some say yes and some say no ,, i do know i have to mod the alt bracket and water neck , i should be able to run the 5.3 injectors and fuel rail ?
please fill in on the basics
thanks ill post some pics later
Old Dec 7, 2014 | 11:28 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: info please
Third gen info is always given out. Since none of that is third gen related, responses will be limited or non existent.
Old Dec 10, 2014 | 08:26 PM
LC2 TECH's Avatar
Re: info please
Your best bet is to go over to LS1tech conversion/hybrid forum and do the research. Not going to go into the logistics here.
Old Dec 14, 2014 | 05:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Actually, the question would apply to a 3rd gen LS swap, so it's cool.
You'll have to tweak the truck steam line a little, but it will work.
Old Dec 15, 2014 | 05:37 PM
Pocket's Avatar
Car: 91 Trans Am
Re: info please
If the 5.3 is from a 99-06 truck, then the long block is externally identical to the 5.7 LS1. If it bolts to the outside of one, it will bolt to the outside of the other much like SBCs were so interchangeable
There are some things to keep in mind, but the majority is direct
Using a LS1 car intake with the truck accessories requires tweaks as the TB will hit the idler pulley and the truck WP water neck. There are simple kits to remedy this, mostly a bracket and denting the neck
The truck 4 corner steam line will not fit under a car style intake without major bending. Since the 5.7 you bought will have one, why not use it
Truck injectors are shorter than car injector, so they do not work directly. There are spacers available but I never liked the design. Whats wrong with the 5.7 injectors/rail?
Old Dec 17, 2014 | 12:43 PM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: info please
Of the 5 truck LSx engines I've seen, 4 of them had a steam crossover up front, and the rear of both heads had gasketed plugs bolted on. I saved a few as spares.
Fanatic1074
Oct 3, 2022 05:57 AM
3rdgenparts
May 21, 2016 11:50 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
