Notching k member for swap
Old Dec 14, 2014 | 11:11 PM
gasmonkey's Avatar
Car: 1992 z28
Engine: 5.7 350
Is this mandatory? I've also seen sbc oil pans made for LS. Would that help any? Trying to clear this up.
Old Dec 17, 2014 | 06:57 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Notching k member for swap
Using 1" setback mounts (hawks/spohn or SBC adapter plates) will put the engine just barely past the K-member without mods when using a Fbody LS1 oil pan. You cannot install the engine/trans combo from the top like this, only from the bottom. It also limits how far down the engine will tilt with the trans removed. Semi helpful for manual conversions, hell to reach the BH bolts on autos. FWIW, I never notched mine
Low mount LSx AC compressors REQUIRE the notch. High mount R4 and sanden compressors require no mods
customblackbird
Aug 15, 2021 10:16 PM
lt1z350
Aug 28, 2015 05:57 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
Linson
Aug 21, 2015 02:12 PM
sreZ28
Aug 14, 2015 07:48 PM
