LT1 SD VS MAF
Car: 1989 GTA
Engine: pending install 383 tpi
LT1 SD VS MAF
Any issues with the 93 SD LT1 vs the MAF LT1's when it comes to upgrades and tuning? Talking F body swaps only
Re: LT1 SD VS MAF
93s use chips similar to 3rd gen's. 94-97 are flashed on the go. Tuning for the OBDI 94-95 PCMs is easier and cheaper than the OBDII systems, but both are capable
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Re: LT1 SD VS MAF
The con is that on a 93, bolt-ons require a tune to compensate, whereas the 94 up will compensate better by measuring the change in air flow.
In a nutshell, the 94up is more forgiving, but if you are a good tuner, either will work very similarly.
Keep in mind the 93 was not true sequential, but a batch fire injection system that fires 1 engine bank at a time. The newer has a slight emissions & drivability advantage.
BumpaD82
Feb 26, 2016 02:57 PM
[For Sale] 4" Spectre MAF Housing/LS7 MAF/Coupler
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
