Which of the late 90's "Vortec" engines were actually LS motors?
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I've been doing some research and found that apparently some of the late 90's "Vortec" truck motors were in fact LS motors? Is there any truth to this? If so, which ones and how can you tell?
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Re: Which of the late 90's "Vortec" engines were actually LS motors?
Vortec was a designation for gm's truck motors from the 90's till now.
The last of the gen 1 sbc's ended in 2003.
http://en.wikipedia.org/wiki/General_Motors_Vortec_engine
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Generally anything with aluminum heads will be ls
Car: 1984 Trans Am
So then my 2006 5.3L Avalanche motor that says "Vortech" on it is actually an LS motor?
Car: 1991 Camaro RS
Engine: 5.3 V8 LS
Any 4.8, 5.3, 6.0, 6.2, 7.0 gm motor from 97+ is based on the LS family of motors that originated from the ls1 in the 97 corvette. The 99+ truck motors were just called Vortec is all.
Car: 1984 Trans Am
Thanks RS/SS. I appreciate the input.
