92 corvette lt1 accessory bracket
Old Feb 16, 2015 | 02:24 AM
CatmanFS's Avatar
Car: 85 Z28
Engine: 93 LT1
Axle/Gears: 3.73 01 SS
Does anyone know how the 92 corvette accessory belt is routed?
Old Feb 16, 2015 | 08:11 PM
Pocket's Avatar
Car: 91 Trans Am
Re: 92 corvette lt1 accessory bracket
Old Feb 27, 2015 | 09:00 AM
Strick1's Avatar
Car: 92 Vette, 83 Camaro
Engine: 305 going to 95 LT1
Transmission: 5 speed going to T56 6 speed
Axle/Gears: 3.73 posi with disc brakes
The 92 Vette used a double sided belt. That means there are grooves on both sides. There was a tech bulletin that change to a single sided belt. But the routing is the same. The only thing I can see as different is the power steering pulley going from grooved to smooth.
BTW, I think this is the easiest way to go when installing a LT1 into a 3rd gen. You don't have to cut the K-member.
BDR
Nov 7, 2015 03:05 PM
L0tuS
Oct 4, 2015 08:07 AM
sahlomonic
Sep 20, 2015 07:15 PM
///DAN///
Brakes
Sep 17, 2015 07:43 PM
L0tuS
Sep 4, 2015 11:16 PM
