4th gen shifter assembly
Old Mar 28, 2015 | 05:53 PM
Brianbajnuth's Avatar
Car: 87 GTA Trans Am
Engine: 5.7 350 TPI
Transmission: TCI transmission
Axle/Gears: 4th gen rear end. With 3.83
Hey Guys just finishing up my ls swap into my 87 trans am. I have a 4th gen shifter assembly from a 2000 Camaro with shifter cable and everything. Seems that no one has ever put the shifter in a thirdgen before. I also have the 4l60e tranny. Will this shifter work?
Thanks in advance
Old Mar 28, 2015 | 08:45 PM
Rich92 RS's Avatar
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
Re: 4th gen shifter assembly
I couldnt find any info back when I tried for my bros 83z 2years ago so i modified the stock 3rd gen shifter to accept the 4th gen cable: https://www.thirdgen.org/forums/ltx-...ml#post5623653
Old Mar 28, 2015 | 09:22 PM
Engine: 5.7 350 TPI
It's not just a straight forward swap? I don't have my old thirdgen shifter assembly.
Old Mar 28, 2015 | 11:33 PM
Rich92 RS's Avatar
Transmission: T56's
I dont remember exactly but i think the 4th gen shifter mounts differently and sits too high for the console to fit over.
Old Apr 2, 2015 | 11:30 AM
Pocket's Avatar
Car: 91 Trans Am
If using the 3rd gen console, use the old 3rd gen shifter and cable. From your old 700R4 remove the cable bracket and shifter arm from the trans. Bolt these directly to the 4L60E for a stock install
Old Apr 3, 2015 | 08:51 PM
Engine: 5.7 350 TPI
I have the 4th gen cable and shifter. I had a b&m shifter and shifter cable. But I sold that. So right now I only have the 4th gen stuff.. Thanks again for the great advice any more advice
Old Apr 4, 2015 | 02:18 AM
quickonslicks's Avatar
hi pocket I could really use some advise, I am currently doing a 5.3 ls swap with the 4l60e trans and im really stuck on the shifter cable the linkage and shifter cable bracket on the trans, at first I took the arm from my 700r4 and used that bracket also with the original cable all worked great until I got my hawks headers. that way will not work the arm is in the way of the middle of the collector. I put the original 4l60 arm on and the headers now fit but the original cable from the 700 does not fit in the cable bracket the came on the 4l60. so I got a 4th gen cable and of course that didn't fit in that bracket either so I got a step bit made the hole bigger to make it fit then I realize that the cable is too short to reach the arm when it in the bracket. im kinda stuck now
Old Apr 9, 2015 | 03:50 PM
Pocket's Avatar
Car: 91 Trans Am
Turn the arm or shifter cable stud around to clear the collector. Its tight in that area no doubt but it will clear
Old Apr 18, 2015 | 08:05 PM
Engine: 5.7 350 TPI
Pocket. Do you know the wiring on a 4th gen shifter assembly?
Like to hook up nns and reverse lights?
Old Apr 18, 2015 | 08:06 PM
Pocket's Avatar
Car: 91 Trans Am
Same as a 3rd gen. Same connector too IIRC
Old May 5, 2015 | 12:54 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I couldn't get my OE cable to work properly with the 4l65e.So I modified a 4th gen cable (shifter side).Plus the bracket that mounts to the trans pan.
1992 Trans Am
May 10, 2023 07:19 PM
cam-mike
Aug 24, 2015 07:23 AM
