Dipstick question
Old Apr 8, 2015 | 10:34 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Dipstick question
So here's the deal... In my attempt to take the dipstick tube off of my 5.3 block (so I could remove the truck exhaust manifolds) I broke the damn thing off in the block. When I got the engine it came with the f-body pan, pick up tube, tray, and what I'm guessing to be the f-body dipstick tube already installed. Now there is a tube sticking out of the bottom of the block and it wont come out. What should I do next? Drill it out or ???
My plan is to install a Lokar black stainless tube as a replacement and I just don't want to mess up the hole in the block before I install this.
Old Apr 8, 2015 | 10:41 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Dipstick question
Will it twist in the hole or is it totally frozen in place?
Old Apr 8, 2015 | 10:51 PM
jharrison5's Avatar
Car: '87 IROC
As far as I can tell it is totally frozen in place. I have removed them before and once the bolt was removed and it was turned a little it came right out. This one I did that and the tube snapped off in my hand. I dropped the pan and tried to tap it out from the bottom up and all that did was start to "mushroom" the end of the tube.
I am a newbie to ls engines and wasn't sure if I did something wrong and now I don't want mess this up any further.
Old Apr 9, 2015 | 04:02 PM
Pocket's Avatar
Car: 91 Trans Am
Grab the tip with some pliers and wobble it back and fourth until it breaks free. It might take a few more whacks with the hammer. Once its loose, use a cutoff wheel to remove the mushroom head and pull the remainder out
Old Apr 10, 2015 | 07:42 PM
jharrison5's Avatar
Car: '87 IROC
This thing refuses to come out... What am I doing wrong here?
Hit it with a hammer and nothing but mushroom
The tube and where it broke off.
Old Apr 11, 2015 | 11:29 PM
Pocket's Avatar
Car: 91 Trans Am
Straiten it back out and hit it harder, itll come out. Stick a long thin bolt inside to keep it strait while whopping it if needed. I had one that absolutely refused to come out even with heat. Ended up driving an easy out in and twisting it to free it
maroe624
Apr 16, 2017 08:29 AM
redmaroz
Aug 16, 2015 11:40 PM
matthew911
Aug 12, 2015 09:38 AM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
