Help with long tube headers on LS swap 90 Camaro
Old Apr 19, 2015 | 04:48 PM
ecstasyrs's Avatar
Car: 1990 RS and 1991 RS
Engine: LS1 and 350
Transmission: auto and manual
Hello everyone, i have a 90' camaro LS swapped and i decided to finally get a set of long tube headers. This is where i need some expert advice, the driver side went in no problem but the passenger side that's another story i have spent the last 3 hours trying to get it in and i can't. Im running a Spohn K member and i already removed the starter and still no luck. Im at a loss as of right now all i have to show for it is 3 busted knuckles rust in the eye and a very sore back. If anyone could help me with this i would really appreciate it. almost forgot the long tubes came from Racing innovation and supply.
http://www.racinginnovationandsupply...e-headers.html
Old Apr 19, 2015 | 10:26 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Re: Help with long tube headers on LS swap 90 Camaro
I had 0 trouble putting mine on both from the top and lifting the front of the car up some.But Im using the stock kmember.Just takes some wiggling if you have a/c. Not sure how the spohn k member is but I wouldve though the extra space would make it easier for you?
Dont give up though,Im sure if will be something small and stupid snagging you up.once it drops in..that moment of success will be worth it.
Old Apr 20, 2015 | 04:40 AM
SsBenj's Avatar
Car: 1989 Iroc-Z
Transmission: Tick Stage 2 T56
Axle/Gears: 2.77
I find it easier to put the passenger side header from the bottom. I have the Hawks Headers though. People usually use a mallet/sledgehammer and hit the header where it doesn't clear. Downside to this is it will restrict exhaust flow and it does not look good.
Goodluck,
Ben
Old Apr 20, 2015 | 02:10 PM
Buggy Disaster's Avatar
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
I installed my passenger side header from underneath. It went right in.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
1984HO
Mar 19, 2021 11:59 AM
italiano67
Dec 11, 2016 09:21 AM
InfinityShade
Aug 22, 2015 08:00 PM
