need help with motor swap info
Old May 19, 2015 | 07:59 PM
alexander13's Avatar
Car: 1991 z28 camaro
Engine: 305 tpi
Axle/Gears: 3.08
i have a 1991 z28 305 tpi 5 speed manual. when i got it i didnt think the body was all too bad but 6 months later i have found that the frame is even shot. so. id like to swap my motor/trans into another camaro roller. what years are compatible with my set up? things to consider with electronics? thanks in advance
Old May 20, 2015 | 08:52 AM
R13_Braz's Avatar
Car: 2014 Z28 #80
Re: need help with motor swap info
First, think this is the wrong subthread as this is for LSX/LTX swaps.
What do you mean the frame is shot? Is it overly rusted? Bent?
90-92 with ease. Any other years with modification and due diligence. I'm thinking you'd have to swap everything (EVERYTHING) to make it work.
Old May 20, 2015 | 09:29 AM
Engine: 305 tpi
Axle/Gears: 3.08
The right rear floor section where the trailing arm bolts up has seperated , allowing the axle to move forwards n backwards. The car has been removed from road duty for everyones sake.
Old May 22, 2015 | 06:36 AM
Pocket's Avatar
Car: 91 Trans Am
The mechanicals fit just about everything 82-92
Electronics are a direct fit for 90-92
88-89 are similar, 85-87 EFI cars still in the running
82-85 cars and 86-87 carb cars are problematic for adapting EFI
Old May 24, 2015 | 06:37 PM
Engine: 305 tpi
Axle/Gears: 3.08
anything i can do for the frame? patch? replace maybe?
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
E Rod
Aug 28, 2015 05:17 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
st.evel07
Aug 13, 2015 06:15 PM
