LS9 clutch/master/slave work with an F-body T56?
Old May 29, 2015 | 08:05 AM
Alice89's Avatar
My boss had a customer who used an LS9 as his power house; he ended up going with a Mc Leod clutch set up. So I have been offered the LS9 clutch/master/slave & I believe the flywheel as well.
Can I use this set up with my F-body LS style T56? Anyone have any experience with this set up?
Any help is appreciated.
Old May 29, 2015 | 08:14 AM
skirocz28's Avatar
Re: LS9 clutch/master/slave work with an F-body T56?
I made a kit to make it work but it involved a lot of parts. It uses a regular conversion flywheel that is used on other LS9 conversion kits such as for the C6 Corvette. There is less bellhousing space in the F-body T56 so I had to make a very short slave cylinder and adapter made from Ram slave cylinder parts and it uses a half in bellhousing spacer to move the trans back. In a 4th gen minor shifter hole modification is necessary but driveshaft shortening was not.
http://store.katechengines.com/ls9x-...ygto-p254.aspx
Old May 30, 2015 | 12:53 AM
Alice89's Avatar
Thanks for the response! Do you know of a place that sells only the conversion fly wheel?
Any more info or pics on your set up? Just curious, thanks.
Old May 30, 2015 | 08:19 AM
skirocz28's Avatar
Here is the flywheel only.
http://store.katechengines.com/ls9x-...heel-p245.aspx
The clutch and flywheel assembly will not fit in the bellhousing though without the bellhousing spacer and a short slave cylinder.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
jharrison5
Aug 19, 2015 05:53 PM
Street Lethal
Aug 13, 2015 08:28 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
