88 GTA 305 TPI swap to lt1 motor questions
Old Jun 9, 2015 | 11:08 PM
sheachopper's Avatar
Car: 1988 trans am gta
Axle/Gears: 4.10
hey everyone I have a 1988 Pontiac Trans Am GTA with a 305 TPI. I am doing the lt1 conversion and I'm running into a few troubles.
1.) will the alternator and all of the pullies off of the 305 fit on to the lt1?
2.) do we need to get rid of the 305 wiring or can we use some of it on the lt1? Anyone have a wiring diagram for both of them?
3.)where is the best place to mount the new lt1 computer?
4.)are there any special connectors we need to add to the lt1 wiring harness to fit some of the 305 accessories such as the windshield wipers fuse box connectors etc.
last but not least, any advice I'm going to need that will make this easier?
Thanks everyone!
Old Jun 9, 2015 | 11:16 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: 88 GTA 305 TPI swap to lt1 motor questions
Thanks everyone!
If you are asking these questions, you have not read the stickies.
Start digging in.
https://www.thirdgen.org/forums/engi...questions.html
Old Jun 14, 2015 | 07:55 AM
Pocket's Avatar
Car: 91 Trans Am
1) No
2) Reuse some of it
3) In the old ECM location
4) Read the wiring stickys laid out in post 3
I recommend you read the sticky a few times and figure out why each of the main points are covered in such detail. Its not a hard swap, but there are quite a few hurdles to overcome and you need to know why these need to be dealt with before starting
Old Jun 14, 2015 | 12:43 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
the engine harness is separate from everything else in the car: the gauges, starter, wipers, and, dome light, power windows, headlights, and anything else on the car have absolutely nothing to do with the engine install.
the ecm will go wherever your harness dicates: if using a Caprice LT1 and harness, the ecm will be behind the driver's side headlight. if using an F body engine and harness, it will be on the passenger side strut tower somewhere... i don't know where the Vettes put it... aftermarket harnesses allow you a lot of room to decide where you want it, but the stock ecm lives comfortably under the hood somewhere.
if running a Caprice harness, you really should go thru and take out all the extra wires.. they bundled the engine harness in the front lighting harness on those cars for some reason, so the headlight, turn signal, horn, and whatever else is in there and needs to be removed to make it into a standalone harness. it's not hard, but it takes time and when you get done you wind up with a self contained harness that only requires a few wires to be hooked into the car itself.
BlueIroc-Z
Jun 9, 2019 03:22 AM
1nastygta
Oct 28, 2015 08:51 PM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
