worth swapping 305tpi to 350 LT1?
Old Jul 11, 2015 | 07:16 PM
86z89iroc's Avatar
Car: 86 z28 daily, 2 89 iroc-z's
Engine: sbc's
I have an 89 iroc-z 305 tpi with upgraded ignition true duals and slp .480 lift cam turbo 350 with small stall and 2.73 rear. Guy wants me to do side job on his 74 nova swapping a sbc to bbc and as payment would give me a LT1 with auto trans wiring harness computer even has fuel tank with pump for the swap. It's supposedly out of 95-97 z28. Would it be worth putting in my 89 as far as power and ecomomy? Was planning on putting the 700r4 back in it to be nicer on street before this came along.
Old Jul 11, 2015 | 09:18 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: worth swapping 305tpi to 350 LT1?
Hell yes as long it's running condition throw cam in it and stall
They make more power due to intake and heads only bad thing is need to upgrade optispark
Do search and look on YouTube etc should explain a lot and should be easy decision to make
Old Jul 11, 2015 | 10:31 PM
Derekltz28's Avatar
Car: 87 Iroc z
Engine: Lt1 350
Done it worked out great opti is a pile tho
Old Jul 12, 2015 | 08:52 AM
86z89iroc's Avatar
Engine: sbc's
I thought about LT4 hot cam and ignition upgrade if I did it. Was thinking the only thing I know I would need is electric to mechanical box for speedo. Haven't done much research to see what else is needed.
Old Jul 12, 2015 | 01:25 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Upgrading to msd I here fixs that issue but idk
Old Jul 12, 2015 | 07:28 PM
86z89iroc's Avatar
Engine: sbc's
How does cooling system work on LT1 to 3rd gen? Doesn't it have reverse flow?
Old Jul 12, 2015 | 09:24 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Same as any it's just reverse flow need nothing special
midge54
Sep 2, 2020 07:13 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
st.evel07
Aug 13, 2015 06:15 PM
