4th gen tank plumbing questions
Old 07-25-2015, 04:22 PM
timonator's Avatar
I bought a 4th gen tank for my LS1 swap and Im trying to figure out what fittings to buy to run the fuel lines. Auto zone and oreillys dont carry the metal efi connectors for the tank fittings. I think I could use ones made by russel for -6 AN but thst seems like a pretty expensive way to go. I've read a couple of the older threads on this. I was wondering if anyone has come up with any different solutions.
Old 09-10-2015, 04:56 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
Re: 4th gen tank plumbing questions
No kidding. To redo the entire system is over $250 not including any hardlines using Russell parts from Summit. Granted the way I figured that was to mimic the OEM routing as much as possible with flexlines at the axle. I've got an LS1/T56 and tank going in this winter. Only thing I'm not sure about is using an LS1 camaro filter or stay with the thirdgen filter.
Sending unit (3/8 Feed) to
EFI to -6AN adapter (644123) to
Tube Nut (660575) to
3/8" hardline to
-6 AN coupler (660353) to
-6 AN flexline (658500) to
3/8" hardline to
LS1 Filter to
-6 AN to 16x1.5 O ring (648060) to
3/8" hardline to
-6 AN Tee* (661023) to
3/8" OEM hardline to
-6 AN flexline (658520) to
LS1 Fuel Rail
Sending unit (5/16 Return) to
EFI to -6AN adapter (644110) to
Tube Nut (660570) to
3/8" hardline to
-6 AN coupler (660350) to
-6 AN flexline (658490) to
3/8" hardline to
-6 AN Tee* (661023)
I've never really messed with -AN fittings before and not sure if some of them can be eliminated. I assume the tube nuts with a flare is a more proper way to do it than with compression fittings. Someone correct me if I'm wrong.
Old 09-12-2015, 08:47 PM
WTR388's Avatar
Car: 87 Trans Am
You can remove the T fitting by using a 'vette filter, it has one in, one out to the rail and the other out is back to the tank.
Using braided hose all the way up to the rail also eliminates a bunch of expensive fittings... And it's simpler to route.
Don't be worried about fabricating braided hoses/fittings. Some good masking tape, a high tooth count hack saw and a vice are really all you need.
Old 09-12-2015, 08:49 PM
Strick1's Avatar
Car: 92 Vette, 83 Camaro
Engine: 305 going to 95 LT1
Transmission: 5 speed going to T56 6 speed
Axle/Gears: 3.73 posi with disc brakes
Just so you know, you can use the nylon tubing for fuel lines. That's my plan. In areas where you think there might be rubbing, just slide some rubber hose over the tubing. It's how they did it in the factory. The nylon tubing is cheaper than steel lines and much easier to work with. Jeggs and Sumitt carry 10 foot rolls and 25 foot rolls. You can buy connectors at the parts stores. Take a look at you tube on how to use the stuff. I'm not going 4 wheeling so nylon tubing will be fine. Okay, flame suit is on. :-)
Old 09-13-2015, 09:43 AM
Marc 85Z28's Avatar
Don't both wasting money on the AN garbage. Too much expense and headache. Factory style nylon lines are more than adequate. I used the Dorman kit and did my entire fuel system for just over $100.
Old 09-13-2015, 09:58 AM
Strick1's Avatar
One more thing good about nylon tubing.....Current gas with ethanol
Frozer!!!
01-19-2024 04:55 PM
Orr89RocZ
04-25-2016 08:28 AM
sweet_87_iroc
09-25-2015 10:01 PM
AkDrifted
08-17-2015 07:45 PM
redmaroz
08-16-2015 11:40 PM
Quick Reply: 4th gen tank plumbing questions
