Truck harness question
Old Jul 26, 2015 | 10:34 AM
madsv1000's Avatar
Car: 1987 Camaro RS
I started depinning yesterday went well just have a question about one wire coming of the C2 fuse block. Cut from the E2 position on the block said its for the transmission, pcm, but I cut it and its just there by itself. Think it went to either the c100 or c102 what do I do with it?
Old Jul 26, 2015 | 11:49 AM
madsv1000's Avatar
Car: 1987 Camaro RS
Re: Truck harness question
Also left r17 and r43 for ac controls I believe this is correct. Still have to go back and put the pins in for the dual fans
Old Jul 30, 2015 | 07:17 PM
madsv1000's Avatar
Car: 1987 Camaro RS
Any body
Old Jul 30, 2015 | 07:21 PM
TecknoMike's Avatar
Car: 1985 Trans Am
Axle/Gears: BW 9 Bolt 3:27
If you're talking about the wire I'm thinking of its the tranny power wire that, on the truck, routes through the truck fuse block first.
In addition to those connections, you need to connect C100 pin C, Pink, to 12v+ RUN/START source. This wire feeds the Transmission Solenoids and PCM. The fuse for this wire is NOT in the underhood fuse block. The fuse was located in the underdash fuseblock in the 99+ pickups. You need to use a 10A fuse for this wire and hook to a RUN/START 12v+ source. This wire runs from C100 Pin C to Underhood Fuseblock C2 - E2. Inside the fuse block, it turns around and comes back out on C2 - F2. F2 then runs to the PCM and Transmission.
http://www.lt1swap.com/underhoodfuseblock.htm
If it is that wire, I'm pretty sure that you won't need to worry about that one. All you'd need is the run the wire that came from F2 to a fuse on whatever fuse block you're going to use. (That's what I'm doing).
But if i'm wrong, here is the website I've been using for my LS swap with truck harness:
http://www.lt1swap.com/2000harness.htm
Last edited by TecknoMike; Jul 30, 2015 at 07:28 PM. Reason: Removed some redundancies
Old Aug 2, 2015 | 02:11 PM
madsv1000's Avatar
Car: 1987 Camaro RS
Thanks man! I asked my wife's cousin he has just done a swap on his blazer so he cleared up a lot of questions.
tricky1
Aug 23, 2015 01:17 PM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
squiggy2
Aug 9, 2015 09:30 PM
