Need fuel problem help!
Old Aug 30, 2015 | 12:07 PM
Justin69's Avatar
Car: 89 Camaro RS
Engine: LT1 w/ 70mm Turbo
Transmission: Stage 3 TR6060
Axle/Gears: 4:10
I went to finally fire my car up and it just cranks and cranks. I have spark but when i depressed the Shrader valve, there isn't anything coming out. It sounds like the pump is priming when i turn the key on but no fuel.
I'm running the Racetronix RXP255 with their Hotwire kit. I have checked all connections and they look good.
Any ideas ? I really am hoping that the tank doesn't have to come back out.
Any help would be greatly appreciated. Thank you in advance.
Old Aug 30, 2015 | 11:01 PM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Re: Need fuel problem help!
Polarity could be reversed on the pump... Seen it happen before.
Fuel hose could have ruptured in tank causing a massive internal leak.
Sounds like you need to pull the tank & verify.
Old Aug 31, 2015 | 11:31 AM
R13_Braz's Avatar
Car: 2014 Z28 #80
Where's the regulator at? Did you check to make sure it all works before re-installing the tank? I.e. fuel comes out?
When I installed my pump, I checked it and it worked. But, a few days later when I was ready to reinstall the tank, I checked again and it didn't work. Took the sender out, and the connector had somehow become unplugged. If it's priming, obviously this isn't the case, but it could be for whatever lines are hooked up, or maybe they are reversed?
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
