Engine price too good to be true
Car: 88 Camaro
Engine: 2.8 V6 For Now
While surfing the web looking for camaro parts as I'm always doing I found this guy sell a LT1 and 4L60 he pulled from a camaro. He says the engine is not lock up and the reason for the cheap price is because he dont know much about the engine. I'm kinda worried because of the cheap price, even tho I will over time do a full rebuild of the engine b4 I drop it in my car. Should I be worried or should I be on my way to grab this engine and trans?
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: Engine price too good to be true
You didn't specify what the asking price is, but getting that from the local self-service salvage yards, $300 for both plus the PCM is realistic. Then a full rebuild probably isn't needed for the engine, probably just a gasket set and a timing set. But it is a good time to install a better cam.
The 4L60E probably does need a full rebuild, especially if it isn't showing signs of a recent one. This is a good time to install a better torque converter.
Car: 1983 Z28
Engine: 385 Fastburn
Ask questions. If the guy doesn't know much about the engine then that's probably most of the reason that it's going 'cheap'.
On the otherhand, sometimes you just find good deals.
MantyZ28
19
Nov 24, 2015 11:10 AM
ryeguy2006a
Exterior Parts Wanted
Nov 4, 2015 03:25 PM
Nervous2
Oct 23, 2015 03:43 PM
