Someone in houston needed help with ls1 swap
Old Dec 10, 2015 | 06:56 PM
729rs's Avatar
Hey guy just bought a 2002 donor camaro and wanna start a swap to my 1990 rs. Been reading alot about this swap but it easier said than done I guess. If someone in houston done this before I'll appreciate all help possible.
Old Dec 11, 2015 | 08:28 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: Someone in houston needed help with ls1 swap
Welcome aboard thirdgen.org.
I moved this to the LTX and LSX sub-forum where it's more likely to be seen.
But, if you're asking for help in-person, you may be better off asking on your regional forum.
I will say that I read and read and researched and searched before I started mine, and it usually didn't make sense until I actually started doing a particular task. Then what I read and researched and searched about made sense.
Old Dec 13, 2015 | 07:23 PM
WTR388's Avatar
Car: 87 Trans Am
That was my experience as well. With where I live there wouldn't be anyone local that has done this, so I dug in and picked away at it, 90% of my info was from this site, some from lt1swap.com, lstech etc.
Honestly it isn't that complicated, I'm excited to see how fast I can do it the second time.
Old Dec 14, 2015 | 11:29 AM
729rs's Avatar
Nice.. Im pretty confident on setting the engine and transmission.. But the electrical part is what's got me thinking
Old Dec 14, 2015 | 03:48 PM
five7kid's Avatar
Wiring isn't all that complicated, there are just a lot of wires to deal with.
Various wiring diagrams are available online. You'll want one for your specific car, and one for your donor car (PCM at least). I found a Mitchell diagram for my LQ4 that proved to be extremely helpful.
Some things are pretty standard and simple - Black is ground, red is battery voltage, pink is switched power. There will be things you don't use, which can be left in place, or removed to debulk the harness.
Using the fuse/relay box from the donor car makes things simpler (in my opinion). There will be a lot you don't use, but those can be removed.
Basically, each wire does one thing (although some ground and power wires are ganged together). Can't get much simpler than that.
dragonmas
Dec 5, 2015 10:11 AM
michael pippin
Nov 24, 2015 07:36 PM
lugnut
Nov 23, 2015 04:25 AM
michael pippin
Nov 21, 2015 09:06 PM
lt1z350
Brakes
Nov 18, 2015 06:32 PM
