My lq9 swap
Axle/Gears: 8.8 373
My lq9 swap
Hey guys I am new to the site and love some of the conversations. Im putting a lq9 with a viper t56 in my 86iroc. The engine has an ls1 intake. I put the engine in last week and now the questions start. The p/s line which work best with the set up is the alternator sits on top of p/s any help would be great tks
Transmission: 4L80E/4L80E
I used 4th gen f-body from the donor on mine. Required some slight tweaking of hard line.
Car: '89 Firebird
Engine: 7.0L
Axle/Gears: 8.8 373
Re: My lq9 swap
Thanks guys gonna see what i can do i will get a 4gen p/s line hope it works lol. As far as the speed sensor goes is there something out there that will work? Tks
Re: My lq9 swap
You can have the trans converted to Fbody specs or run an external VSS pickup. Jags that run sells a differential yoke mounted reluctor. If running a 4ch 10 bolt as a basis for your 8.8, run the VSS wires to that. If your 8.8 diff was from a newer ford with traction control, run the VSS to the speed sensor on top and adjust the speed scaler in the tune
