Put in HID's not my dash lights wont come on
Old Nov 16, 2015 | 01:14 PM
propaintball96's Avatar
Hey guys,
Just but HID's in my 85 Camaro. The signal 12v wire only connects to one of the original headlight plugs so I believe the car thinks the other head light is out there fore the dash lights will not come on. Anyone know how I can trick the car into thinking the other head light is in (short it out somehow) and it will make the dash lights come on?
Thanks!
Old Nov 19, 2015 | 11:15 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Put in HID's not my dash lights wont come on
You only need one 12v signal to rigger the HID relay/s, which then switch on the ballasts.Dash lights should work even w/out the headlights connected.So no trickery is needed.Something else is the problem.
Maybe you rotated the headlight **** to the off position, fuse is another item to check.
Old Nov 19, 2015 | 11:34 PM
Thanks for the reply. I'll check the fuses again. Also i just found out I have one of the small corner tail lights out...could be that also. Thanks!
EllisUFC
Oct 26, 2015 10:13 PM
IROCZ28KevinZ
Mar 25, 2002 02:13 AM
West Coast GTA Man
Aug 7, 2001 06:56 AM
maksik7
Jul 30, 2001 08:33 AM
RED91Z
Jun 4, 2001 10:12 PM
