LM7 into 91 RS. T56 bonus question.
Old Apr 16, 2016 | 12:43 PM
"John"'s Avatar
Car: 91 Camaro RS
Engine: 350 crate engine 360ish HP
Transmission: T5 5 speed manual
Axle/Gears: 3.42 10 bolt POSI
! am looking to put a LM7 into my 91 RS. I understand that the stock intake manifold will be too tall to fit under the stock hood. Would a cowl induction hood be able to fit the LM7 manifold?
Also there is a relatively inexpensive 95 z28 in my area with a T56 that I am considering for a Transmission/rear end/drive shaft swap. How difficult/expensive is it to swap the LT1 T56 to fit the
LM7? I understand I would need to swap the bellhousing, input shaft, clutch and midplate. Is there anything I'm missing here? The donor car is gonna be $3000. Will I be able to part out the rest of it and still come out money ahead from buying the tranny and rear end separate, despite the transmission conversion?
Old Apr 18, 2016 | 04:13 PM
R13_Braz's Avatar
Car: 2014 Z28 #80
Re: LM7 into 91 RS. T56 bonus question.
If the trans is in good condition, I'd do it. You are looking at around $5-800ish for the LS T56 swap parts, but it's worth it. Don't forget about the hydraulics as well... LT1 stuff won't work with an LS T56.
Search around for deals. I have some links to the stuff I bought in my build thread (2nd post, should have a Google Drive link to my build spreadsheet).
As for your first question, I'm not sure.
dennisbernal91z
Apr 14, 2016 05:42 AM
89irocz355
Exterior Parts for Sale
18
Apr 11, 2016 10:17 PM
i88aGT
Apr 6, 2016 06:53 PM
camcore
Mar 30, 2016 02:46 PM
Nick Fletcher
Mar 22, 2016 01:19 PM
