LT1, 9C1 in trans am GTA
Old Apr 12, 2016 | 01:07 PM
Mattis's Avatar
Hi!
I have a trans am GTA -87 whit The digital cluster.
Im have a LT1, 9C1 whit original 4L60E transmission, ECU and harness.
Can you help me how to wire upp The cluster!
What do i have to do?
Old Apr 19, 2016 | 02:23 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: LT1, 9C1 in trans am GTA
the gauges in the cluster should be independent of the engine control harness, so swap over all sensors from the old engine to the new engine and it should be good to go.
Old Apr 20, 2016 | 09:36 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The signal from the PCM to the cluster either already is, or can be tuned to use the same 4004ppm signal as your 87 used. You may need to tune for a change in rear gear.
ars2pd
Apr 12, 2016 01:33 PM
Chough262
Apr 10, 2016 01:20 PM
85@IRocZ
Apr 8, 2016 02:41 PM
B4C5.7
Apr 8, 2016 05:40 AM
firechickenmike
Interior Parts Wanted
Apr 7, 2016 07:52 PM
