factory computer with motor swap
Old Jun 6, 2016 | 02:13 PM
Jacob Lee's Avatar
So this is probably a stupid question and common sense since I can't find the info anywhere but let's say theoretically if I swap a third a5.3 truck la motor into a third gen am I able to use the factory computer and wiring harness without having to "tune" anything like just plug in and connect everything?
Old Jun 6, 2016 | 08:24 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: factory computer with motor swap
I take it you want to use the factory 5.3 computer correct? The factory computer from your 3rd gen wont work at all with a 5.3.
You will have to slim down the 5.3 harness and remove some stuff your 3rd gen doesn't have, and there are a ton of threads dedicated to doing that. You will also have to tune the 5.3 computer to remove the VATS and a few other things not needed for your 3rd gen.
Old Jun 8, 2016 | 03:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
If you mean "Gen III 5.3", then yes, this is your basic "LS swap". There is a sticky in the top section of this forum with the basics of the swap (details depend upon the source of your 5.3). There is a link within that thread about what you need to consider when starting with a truck engine.
As jharrison5 said, the computer in your car won't work with the 5.3. In fact, you can remove it as anything it does can be handled by the 5.3 PCM. Some rewiring required.
'91CamaroRS
Car Audio
Apr 3, 2016 07:45 PM
90 L98 TransAm
Exterior Parts for Sale
Mar 30, 2016 05:33 PM
philmcgroin
Mar 28, 2016 02:13 PM
iiAmDomo
Aftermarket Product Review
Mar 24, 2016 02:27 AM
Rumblebee
Mar 13, 2016 06:49 PM
