Tune up gone wrong. HELP
Old Mar 12, 2016 | 12:18 PM
Rumblebee's Avatar
Hey everyone,
I have an 88 Iroc TBI 305 that i just installed new plugs wires and dizzy cap onto.
One of my distributor cap bolts snapped so i had to remove the whole thing which has lead to where I am.
The car is turning over with an occasional popping from the rear but wont start. I have tried so many different combinations along with putting the old stuff back on with no luck.
Im using 18436572 firing order clockwise
8 7
6 5
4 3
2 1 as my guide
TDC the rotor is pointing #1 cylinder
Plug gaps at .035
Ive tried moving the dizzy around with no luck also I tried rotating it 180. and I tried rotating the wires 180. No combination is working.
Any insight appreciated.
Mark
Old Mar 13, 2016 | 10:31 AM
Vader's Avatar
Re: Tune up gone wrong. HELP
That should work. Is there voltage at the coil primary? Is the four-wire flat connector clean and fully seated? Are the new plugs fuel fouled?
Old Mar 13, 2016 | 10:57 AM
UltRoadWarrior9's Avatar
Car: 1986 IROC Z-28
Engine: 383 Gen I SBC 11:1
Transmission: Rebuilt TH700R4 for 500+HP
Axle/Gears: 4th Gen 10 bolt Eaton Truetrac 3.23
Maybe what the OP thought was TDC on the compression stroke, was TDC on the exhaust stroke? Just a thought, especially since your getting a 'popping' out of the exhaust...
Old Mar 13, 2016 | 06:49 PM
Rumblebee's Avatar
Thanks for the replies,
I managed to get it going, after switching wires around again i found the #1 starting point was a post to the right. I cleaned the throttle body and put all new gaskets in it and cleaned up the IAC and TPS.
While doing the fuel filter a line broke, so that is my next ordeal.
I was still experiencing a high idle, it is reading at 2000 and fluctuating down to 1500. I don't have high hopes on the new fuel filter helping.
Any insight there would be helpful.
gladback007
Feb 28, 2016 04:05 PM
BovineZro
Feb 26, 2016 05:07 PM
irocz43
Feb 24, 2016 05:41 PM
ezbyrd
Feb 17, 2016 06:38 PM
Mefis
Feb 13, 2016 05:02 AM
