89 GTA LS3 engine swap
Old Jul 6, 2016 | 08:47 AM
RJcorc's Avatar
Hi guys,
I have an 89 GTA Trans Am and I am playing with the idea of an engine swap. GMperformance crate engines has an LS3 430 h.p. motor that I am very interested in. Has anyone swapped the 5.7 original with an LS3? If so any advice? Does the original 700R4 tranny work? Any extra parts that will be needed?
Thank you
Old Jul 6, 2016 | 08:58 AM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Re: 89 GTA LS3 engine swap
https://www.thirdgen.org/forums/engi...third-gen.html
Start with the above sticky, it says LS1 one but most of the same principles apply to LS3 as well.
Old Jul 6, 2016 | 09:00 AM
RJcorc's Avatar
New to the site, Thank you
Old Jul 9, 2016 | 12:10 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
The sticky will give you the basics of bolting it in. Details will depend upon exactly what you get. The controller kit they sell for the crate engine is a good idea if you can swing the cost.
TH700 behind an LS generally isn't a good idea. But, if that's all your budget can handle, it can be done. Biggest problem is the LS3 is drive-by-wire, and the TH700 requires a throttle cable to operate properly - by the time you resolve that, it may make more sense to just get an LS-style 4L60E.
89irocz355
Mar 28, 2018 08:24 PM
89irocz355
26
Sep 12, 2016 01:28 PM
TheFab
Mar 19, 2016 07:39 AM
farm-kid/88camaro
Aftermarket Product Review
Jan 14, 2001 11:30 PM
