Injectors are not working
Old Jul 11, 2016 | 06:52 PM
Redwhisper's Avatar
Car: 86 IROC-Z
Engine: 97 LT1
The 1997 LT1 in my 86 Camaro will fire if I spray start fluid in the intake, but the injectors will not deliver the fuel. I have fuel at the fuel rail, and the injectors all have 12.5 ohms across them. I have checked the crank connection, the MAP connection and all the other connections I can find. I looked for a cam sensor, which someone suggest, but couldn't find one. Pocket made the harness so that is all good. What other sensor would tell the PCM not to fire the injectors? The air intake is off the car, is the MAF a critical sensor, I didn't think so. This is very frustrating. Thanks for any help.
Old Jul 12, 2016 | 09:16 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
The opti spark is your cam sensor. Possible problem with the opti? I would think you'd lose spark too though. Pocket is pretty spot on but I'd still check the harness. Specifically the opti pigtail.
Old Jul 16, 2016 | 07:27 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Injectors are not working
^ Yup, and the TPS too
L0tuS
Mar 30, 2016 03:21 PM
MecGen
Mar 22, 2016 05:05 PM
xkingcodex
Exterior Parts Wanted
Mar 22, 2016 01:45 AM
db057
Mar 14, 2016 08:53 PM
Auggie
Aftermarket Product Review
Nov 2, 2000 02:17 PM
