LS Swap Fuel Fitting Part Numbers?
Old May 5, 2017 | 12:33 PM
Streetstuff's Avatar
Car: 1985 Camaro
Engine: 5.3
Transmission: 4L80e
Axle/Gears: 3.42 10 bolt
I can't seem to find the part numbers for the fittings. Going with a Walbro F20000169 pump in the original tank to a truck 5.3. I've seen 640850, 640860 and 644123 thrown around but idk if its right or how many I need. Sorry I'm a noob when it comes to fuel stuff.
Old May 8, 2017 | 12:45 PM
redmaroz's Avatar
Car: 92 Z28
Engine: ls3
Transmission: t56
Axle/Gears: 4.11
Re: LS Swap Fuel Fitting Part Numbers?
Don't know if this is what you are after or not, but page 3 post 117 has a lot of the part#s. https://www.thirdgen.org/forums/ltx-...s1-swap-3.html
Old May 8, 2017 | 02:52 PM
Car: 1985 Camaro
Engine: 5.3
Transmission: 4L80e
Thanks, I'm running an lm7 so I won't need the Wix 33737 regulator, but that should help me get this straightened out.
