700-r4 to Lm7 TV Cable for DBC EFI
Old Oct 5, 2017 | 03:37 PM
Streetstuff's Avatar
Car: 1985 Camaro
Engine: 5.3
Transmission: 4L80e
Axle/Gears: 3.42 10 bolt
My lm7 swap is "complete" minus the TV cable. I know they have to be adjusted just right or the trans dies early but I can't find where to get one. I would assume the original one that went to a carb will not work because it is not long enough to reach the throttle body? I've seen a lot of threads that mention Bowtie Overdrives but no part number or anything. Stock truck throttle body and intake btw.
Old Oct 17, 2017 | 12:06 PM
Car: 1985 Camaro
Engine: 5.3
Transmission: 4L80e
Re: 700-r4 to Lm7 TV Cable for DBC EFI
So it turns out the TV cable does come out on the correct (passenger) side it was just routed behind the engine. it is a few inches too short though. I saw a picture where someone extended the connection on the throttle body to make a short cable work. I'll get some pics.
Old Aug 21, 2020 | 11:10 AM
Hawkswings's Avatar
Not to bring to life a dead thread from 3 years ago, but the cable wire from a 3rd gen 2.8 l is exactly long enough. If you have a drive-by cable throttle body, take the cruise control mount, flip it around and it is exactly the right length.
LoudmouthSS
Dec 22, 2005 08:01 PM
1986camarojoe
Jan 15, 2005 01:42 PM
IROCThe5.7L
Mar 30, 2004 08:51 PM
