LSX454 or GMPP BIG BLOCK SAME PRICE
Old Dec 21, 2017 | 07:58 PM
aussiesteve's Avatar
Car: 1982 z/28 Right hand drive
Engine: 377 AFR195 750DP Solid cam 10.25:1
Transmission: TH/350 3200 stall spohn conversion
Axle/Gears: 10 bolt 3.42:1 Eaton Trutrac.
looking at replacing tired 408 sbc with either a big block or LSX ..what is easyest and cheapest to get 600hp..currently running th350 and eaton trutrac 10 bolt...12.87@111mph..
bolting in is no problem...its headers,,p/steer and alternator brackets and pulleys..water hoses,,,radiator necks changed,, currently running a 4 core brass unit and its great
Old Dec 21, 2017 | 08:04 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: LSX454 or GMPP BIG BLOCK SAME PRICE
Why not just rebuild and upgrade the 408? Afr 220 head and a 246-250 deg hyd roller will get there
Old Dec 21, 2017 | 08:13 PM
the 408 is +060 and internal balanced cast crank,stock 8.7:1 comp,,,to step it up and run harder i need new bottom end,,new AFR top end,,a 427 dart short motor is a possability with AFR top,,i need new cam then its a new engine.or LSX454 at 10.5 k or zz427 at 11k
Old Dec 21, 2017 | 08:35 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Well if the money is there and you want a crate you should do the lsx. Smaller package fits better and lighter
Else buy a 416 shortblock ls3 deal. Stock ls3 heads and intake with a stage 3 stroker cam will do 620 hp. Much cheaper in the end
Old Dec 21, 2017 | 10:19 PM
I have a commodore SS its the LS2 L98 i think version 6.0 litre,,same as the pontiac G8.
i am new to the Ls motors and unfamilliar to buying or building hybrids,,
i can get a new motor built here but parts are a bit expensive being imported and a good 550hp 383 6000rpm sbc will cost $10,000 U.S.
i may run low 12,s
my way of thinking is go with a factory crate engine and keep it maintainance free and reliable and keep it simple and the LSX 454 iron block looks a simple turn key racer.
i could go an LS3 or even a basicly stock LS2 with a $4000 blower like a magnacharger that sits to the side of the head and looks like a big alternator.
i am installing new valve springs on my vortecs and give it another run.
aussiesteve
Dec 14, 2017 08:10 AM
95Cam86Roc
Jan 10, 2012 02:15 PM
sk8r fer life
Jun 4, 2011 08:37 PM
Iroc You
Jul 27, 2009 06:21 PM
Z28 Boy
Feb 14, 2001 07:44 PM
