got a price on the GMPP Vortec TBI intake....
Old Feb 13, 2001 | 01:56 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
I got the price from teh guy that helps me out at the local dealer...my price for the intake was $335 and he said it will take 2 days to get, but he doenst know how long till it actually gets ordered.
but that price of $335 though is my price, as in thats not the normal price. i am assuming that the "normal" price is like 400 - i think i saw "$409" on the screen, but i didnt get a chance to look at whether or not that was the list price.
little pricey for me, but its still kinda cool.
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Intake, Holley 670 CFM TB, Edelbrock Water Pump, March Pulleys, MSD 6AL, Blaster Coil, 8.5mm Super Conductors, Cap and Rotor, Rapidfires, Hypertech Fan Switch & Chip, SLP 1 3/4" Stainless Headers, 3" Cat Back, Flowmaster 40 Series
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
GM 10 Bolt -coming soon Auburn Pro Series Differential, Richmond 3.73s
Brian's 1991 RS Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
Old Feb 13, 2001 | 10:48 PM
rsilver's Avatar
Z-28, I got a price of $329 from SDPC yesterday. They have recieved one so far and expect to get more in the future.If it is a bolt on for my car, I am ordering one with a crate vortech. If it takes a bunch of mods to make it work, its not worth it for me........bob
91 camaro RS L03 convert,
t-5, ultimate TBI mods,TBI spacer,SLP 1 5/8 headers,
3"cat back, 3.42 torsen posi,alston SFC's,Global West LCA relocation brackets, edelbrock STB
Old Feb 13, 2001 | 11:38 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
i dunno man...it just seems like a damn high price. the other thread i made about it someone said they saw it and that it looked just like an edelbrock one, and that they werent impressed with it. im still undecided though.
-brian
Old Feb 14, 2001 | 12:01 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
FYI. DEALER COST. = Scoggin dickey, etc... retail price.
this is because these guys get discounts when they buy because they are performance parts dealers. my parents dealership bought vortec 350 heads for 209 a peice. what are they from scoggin or others?? about that price.
Old Feb 14, 2001 | 12:20 AM
rsilver's Avatar
z/28, I see you are already set up with the vortec engine and as I recall I saw your site and read about the hassel it was to get everything working with the edelbrock carb manifold. Given that you already went through all of that I wouldn't switch to the TBI version. The only reason I am doing it is cause it looks pretty easy and most of my stuff will bolt up and for the extra $200 on the manifold I think I will make up for it in time saved. Not sure how much performance if any I will lose over the carb intake version. Anyway, I'm gonna do it so will let you guys know how it goes.
One thought though, the Vortec crate engine makes its Hp and torque mostly below 6,000 rpm which seems like a good way to go for TBI.
It will sure be a lot better than the caprice LO5 I was gonna do.........bob
Old Feb 14, 2001 | 09:56 AM
Ken73's Avatar
Car: 82 Corvette
Engine: 350 CrossFire
Damn, you guys beat me to it! However, I sent a mail to Jim Pace about it and they sent me one back with $306 as a price. They said the three holes up front are for the EGR.
Ken
Old Feb 14, 2001 | 10:26 AM
Max's Avatar
Max
Car: '89 Camaro Convertible
Engine: LB9 Heads/LT1 Cam Holley 670 Carb
Transmission: T5 Manual
Question:
Does the GM piece have the standard size bores. I think I heard that the Holley adapters have larger bores. Does it matter?
If not I say keep it simple and go without an adapter.
Black 1989 RS Convertible w/43,000 mi.
Excellent Condition
LO3 305 w/TBI
12 PSI Fuel Pressure
6* Timing Advance
MSD Coil And Wires
Open Element 14x3 K&N
Hypertech Thermomaster
160 Degree Thermostat
Low Temp Fan Switch
Eddlebrock RPM Muffler
No Cat/No AIR Injection
B&M Stage 2 Shift Kit
17"x8.5" ATP 5 Spoke Alloys
P 245/45 Goodyear Eagle
HP Ultra Plus Tires
Lakewood Control Arms
Lakewood Pan Hard Rod
Coming Soon:
Hedman Headers & Y Pipe
12 Bolt With 3.73 Gears
NOS System
Old Feb 14, 2001 | 11:20 AM
FastBroker's Avatar
Snuf, the Vortec heads are only $209 or so from SDPC... They (SDPC) cannot be beat... Are your parents paying that much for them from GM??? Somethin ain't right. They should by from SDPC and get SDPC's volume discount and they'll even be cheaper!!!
You never got back to me on the OEM 2" Rochester TBI unit, by the way. Still waiting for your reply on getting one.
ON TO the poster's topic, NO, I do not think that manifold is worth it. I would go RPM Air-Gap with an adapter plate that is custom cut to match carb pod outer dim's so it doesn't look all bulky.
[This message has been edited by FastBroker (edited February 14, 2001).]
Old Feb 14, 2001 | 06:25 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
i looked at a picture of a vortec head and do'nt see a heat riser port.without the port what does the egr in the intake hook to?
Old Feb 14, 2001 | 07:44 PM
rsilver's Avatar
The egr will run to the Exhaust manifold or header via a truck type adapter that taps into the manifold.....bob
MustangBeater20
Oct 29, 2022 09:20 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Fast355
Dec 2, 2016 06:33 PM
z28addict8490
Sep 5, 2015 03:56 PM
