Hawks DBW Pedal Adapter
Old Aug 11, 2018 | 08:07 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Anybody used one of these on their swaps? I just got mine mounted up and am wondering what hawk's intentions are for the upper mounting hole where the throttle cable used to go through the firewall. I know obvious solution is to bolt it, but the opening is pretty large and would require a pretty big washer.
See pic below
Old Aug 11, 2018 | 08:35 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Re: Hawks DBW Pedal Adapter
I made my own pedal pedestal.
I went to my local Ace Hardware store and got 2 neoprene washers along with two regular washers and bolted them. The neoprene holds up well to heat and the elements and weather seals the opening. Works perfectly.
I did not want to permanently seal it up, as there might be a future use for wiring into the cabin - who knows?
Attached Thumbnails Hawks DBW Pedal Adapter-ls2-swap-009sm.jpg   Hawks DBW Pedal Adapter-ls2-swap-010sm.jpg
Old Aug 12, 2018 | 08:08 AM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Perfect! Thanks for the reply!
Grifter757
LSX and LTX Parts
18
Apr 9, 2013 08:12 PM
TEDSgrad
Nov 30, 2011 06:00 PM
HDon22s
Jan 23, 2009 06:56 PM
