Hooker Blackheart System users
Old Dec 6, 2018 | 12:25 PM
Realmac4's Avatar
Car: 1991 Z-28/ '94 Impala SS
Engine: 355 TPI/ 350 LT-1
Transmission: T-56 in both
Axle/Gears: 3.73 / 4.56
Those of you using Hooker Blackheart systems, how do you like them? I am looking at a LS swap next year and the mild steel coated headers and stainless exhaust systems are on sale and I am thinking of picking them up. I know there are other cheaper options for headers, but want a system that fits nice and tight and not have to do much fab work.
Mike
Old Dec 6, 2018 | 02:49 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Hooker Blackheart System users
Mike
I've been struggling with engine position and have tried various mounts, bushings, and cross members. The Hooker headers fit perfectly through all my various combos', and still do now that I have the engine position dialed in. The collectors tuck up nicely and the flanges are perfectly welded. They are incredibly well made. Expensive, but you get what you pay for. It is a well engineered piece as documented by Holley Tech Todkey on this site.
Image of them on the motor outside of the car with black ceramic coating.
Old Dec 6, 2018 | 03:18 PM
Realmac4's Avatar
What cross member is that? I have AJE racing, looks somewhat similar
,and will be T-56 as well. Are you running the entire system?
Mike
Old Dec 7, 2018 | 08:08 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Mike
I'm using the UMI road race K-member, Their engine side solid mounts and k-member mounts. I'm not going to run the entire blackheart system. The dual 2.5" might be a bottleneck for me.
Old Dec 7, 2018 | 07:45 PM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
Can you use the Holley trans crossmember with Spohn mount brackets? I have the Hawks xmember but am not happy with the fitment.
Old Dec 7, 2018 | 07:47 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Maybe but I doubt it. Holley designed their stuff to be used together which places the engine forward a touch. Just buy the Holley mounts if you're using the stock kmember. They are around $100.
Old Dec 8, 2018 | 01:34 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
I have there hole kit on my car from front to back its the best fitting exhaust i have seen on these cars period! Also gives the best ground clearance far as i can tell and Hawks is running it on there project Moe Dirt 850-1000hp camaro. With that out of the way the sound from the blackheart cans is some what mild Bruce even said this to me in person when i was looking over there car.
Old Dec 17, 2018 | 07:12 PM
92BLKL98's Avatar
I decided to buy the Hooker cross member and it's associated bracket to mount the 4L60E trans. I am using Spohn mount stands and the Hooker cross member fit perfectly. This has to be one of the best design frame pieces I've seen, no modifications to anything to make it fit. The engine position is good, the powertrain angle looks good. This certainly beats the Hawks piece I had to grind on to make it bolt up. I am using Speed Engineering 1 7/8" headers and they route good but having a 3" collector the pipes will be tight going by the cross member but they were tight with the Hawks piece too.
Old Jan 14, 2019 | 08:16 AM
gixxer92's Avatar
Car: 1986 IROC, 2017 Silverado
Engine: 7.0L, 6.2L
Transmission: Tremec Magnum, 8L80
Axle/Gears: 3:23, 3:55
I don't like what I would call "belching" at idle I hear. I'd like to see an X-pipe in place to even out the pulses on a larger cam'd car. Love the system overall though!
My engine sits in fine with Moroso lower motor mounts and energy suspension poly SBC upper attached to the adapter plates.
86Base
May 3, 2020 08:32 PM
COSPEED
Sponsored Vendors
Dec 8, 2017 02:26 PM
gtorep
LSX and LTX Parts
Jun 19, 2017 11:30 AM
Alice89
LSX and LTX Parts
Feb 23, 2017 09:55 PM
COSPEED
Sponsored Vendors
Nov 21, 2016 05:19 AM
