LS swap A/C question
Car: 1990 IROC-Z
Engine: 5.0 TBI
I’ve read through several threads and searched but haven’t seen anyone address how to handle the changing the A/C from R-12 to R-134. When disconnecting the A/C do you have to discharge the system a particular way or at a shop? Do all of the 3rd gen parts swap over if you’re using the 4th gen compressor? I’m assuming mine is still R-12 even though it’s blowing cold. Thanks
Slice
Slice
Car: '89 Firebird Formula
Engine: TBI 305
Axle/Gears: 10-bolt, 3.42s, Torsen diff.
Re: LS swap A/C question
You can find a wealth of information about the R12/ R134 conversion on the cooling board of this site.
No 3rd gen parts will match the 4th gen compressor.
Don't discharge your system into the atmosphere, take it to a shop.
Car: 1989 Firebird
Engine: 5.7 LS1
Take it to a shop and have them discharge it and flush the system. The oils between r12 and r134 isn't compatible and will turn to sludge if you mix them.
If you use a top mount ac bracket you can find one that works with a 3ed gen style compressor and run r12, if you keep the 4th gen compressor in the low mount position it will have r134 oil (PAG) in it and I would choose to run r134 in the system. While you are at it if you replace the condenser with the 91/92 model it works better with the the 4th gen compressor. You will want to replace the dryer and expansion tube also. I would also re o-ring the system the r134 o rings are a different material than the r12 (the r134 are green, r12 are black).
People have ran all the 4th gen parts but they don't quite fit.
I ended up replacing 100% of my AC system with my swap, the only used part was the hard lines to the compressor from the 4th gen donor, I took those to a hydraulic shop and had them reworked to fit the thirdgen.
BlueZee28
Sep 6, 2009 10:35 AM
porkyzilla
Aug 14, 2004 08:49 PM
Team P.S.I.
Jun 21, 2004 05:50 PM
86WS6_T/A
Feb 26, 2004 06:32 PM
