wake the beast
Old Mar 25, 2019 | 09:28 PM
Jimmy61579's Avatar
wake the beast
Hello,
my name is Jim S.
My brother bought a 1986 Pontiac firebird trans am with a factory tuned port injection motor; about 10 years ago... it was manufactured in 11/85...
it has just been sitting ever since!! So, I decided to take it off his hands!!!
When he got it; it was not running, and he was told that all it needed was a fuel pump!! He tried to drop the tank and got about 1/2 of it taken apart when he decided to just pull up the back rug and cut an access panel to it from the top!!
Which he did and installed a new fuel pump to no avail!! the car still would not start: and he just left it covered in the back yard!!
I piddled with it off and on over the years until I took it over last summer!!
I have replaced multiple parts my latest being the computer and still no luck!!!
when I turn the key on only a few gauges start to move and only the seat belt light lights up!!!
it will turn over and if I hit it with some Either/ starting fluid it will crank up and purr like a tiger!!!
I’ve checked all fuses and relays and all the things 1 would normally think of!! but I CANNOT GET THE FUEL PUMP TO TURN ON TO SAVE MY LIFE!!!
UNLESS I run power straight from the battery to the Fuel PUMP IT WILL RUN PERFECTLY!!!
I have come to believe that it might have something to do with the VATS alarm system!!!
I have Read & Watched so many videos & articles about how to bypass the VATS system or been told that I need to buy a VATS delete chip which there are many to choose from, or to unplug the "BCM" Body Control Module while starting then plug it back in after it starts!!!
But I have also been told that the 1986 model did not have a VATS system or a "BCM",
or that there is a fusible link I could put in somewhere to bypass the alarm system!!
or it is the neutral safety switch, or I need a new key switch but if I did that the KYE SWITCH would have to be SYNKED to the Computer?? Or to do this or that!!!
I am begging for someone who has Some knowledge of my year of firebird or trans am as it has the markings of both!! To please tell me decisively tell me what I need to do so I am no longer just throwing money at it!!!!
Thank you for any assistance in advanced,
Jim S
Jimmy61579
Mar 25, 2019 09:54 PM
KeithO
Pacific Northwest Region
Sep 12, 2001 11:43 PM
Adams87Camaro
Jul 9, 2001 10:54 PM
lukerene
May 17, 2001 09:28 PM
Brandog87GTA
Apr 23, 2001 08:30 AM
