wake up 305!!
Old May 16, 2001 | 06:23 AM
lukerene's Avatar
Car: 1982 t top,,z/28,
Engine: 409ci vortec
Transmission: all steel t700r4,1300 stall yahooooooooooo
wake up 305!!
i have got a 305 z./28 stocker,,duel snorkel intake 4 bbl ,,i just bought a ISKY 262 cam ,435lift,262 duration 0;50@ 208 dur,,(small one),i intend swaping the heads and the intake,,,,i need usable power 1500<5500, what is the story on the heads,,,i been out of this stuff for years,,,i want to keep it relativly lo comp,,,,and can get excess to a head shop to get porting done,,,which is the best stock head to start work on,,,1982 z/28 305,,,and will they have markings on them like the old fuellie,,heads,,or whatnot,,
Old May 16, 2001 | 08:39 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
If you want to get different heads I would get the Wold Products 305 heads, I've heard good things about them. Also the Vortec heads that GM makes flow well but you would need to buy a special intake for them. Most aftermarket heads are designed for the larger bore of a 350 or other engines and won't work well on a 305.
You also might want to look into working with your stock heads, I've had success with that. I had my heads ported, 3angle valve job, the bowls blended, and they are milled for more compression. I've managed to get my 305 down to a 13.4sec 1/4 mile with the stock bottom end with the mods in my signature.
best 1/4 mile so far: 13.4 @ 101mph
84 Camaro 305 ported & milled heads, 3 angle valve job, Edelbrock Performer RPM intake, Hedman full length headers, Accell ignition, Crane 274H cam, B&M 700R-4, 3000 stall speed, 4.10 gear,
M/T ET street tires
visit my website at http://www.geocities.com/jbenge/page1.html
Old May 16, 2001 | 08:48 AM
Steve89GTA's Avatar
JBENGE, with that cam how did your streatability react? Can you still drive the car daily and does it burn gas like a ****?
Your setup looks great and I'd love to get down into the 13's. How much did it cost to do the head work?
Steve
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
New Fuel Pump!
Autometer Vac+Oil Temp
2000 Yamaha R1 150hp 385ibs
Old May 16, 2001 | 09:10 PM
jbenge's Avatar
The cam in combination with the 4.10 gear makes the car drink gas so I wouldn't recommend it for a daily driver but besides that its very reliable and streetable. The head work cost about $250 plus another $80 because I had the exhaust valves replaced with better flowing aftermarket ones. I had the heads tested on a flow bench before and after the work, it made a huge difference. And when I put the heads on the car I could definately tell a difference in throttle response so it was definately worth the effort.
M/T ET street tires
Old May 17, 2001 | 05:47 PM
Iroc87's Avatar
What else was done to the heads ? Did you change valve sizes? What was the CR after the milling? 13.4 1/4 with a 305 I WANT THAT!!!!!!
Original owner 1987 Iroc
Stock but not for long
Old May 17, 2001 | 07:58 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
I have the Vortec heads on the 305 I am building and other than milling them down to get the CR. I would recomend them to anybody and the valve size works well with the 305.
Brian
Old May 17, 2001 | 09:28 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Do the WP heads. I ported my own 305 heads, and spent $460 on getting them reworked. I ended up running 101 MPH as well, but I dont think I have the correct torque converter. THe motor is a bit shy on torque below 3000 RPM, and my 60-foot times are still 2.05 to 2.1 seconds with virtually zero wheelspin.
I have many, many details about it on my website.
http://www.isthq.com/~dan/fcar.html
Daniel Burk
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff., Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
Best of 14.039 at 100.82 MPH in Stanton, MI
New! 275-40-ZR17 tires on ROH ZS 17 x 9.5's
pjsparts
Oct 29, 2025 06:39 PM
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
