Trans choice
Old Sep 28, 2019 | 11:01 PM
LDR's Avatar
LDR
Car: 2012 Impala ltz 1988 Gta project
Trans choice
From those that have done it. In a street strip car. Would you run a Th400 or 4l60e. I’m planning 500+whp.
Old Sep 29, 2019 | 07:44 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Trans choice
If you had said street only, I'd say 4l60e.
Strip only, TH400
But since you said both, 4l80e
Those would be my choices if I were forced and automatic. I really prefer an overdrive on the street but a 4l60e tend to be a weak link on the track. 4l80e not so much a problem handling abuse.
To each their own, good luck.
Old Sep 29, 2019 | 09:08 AM
LDR's Avatar
LDR
Re: Trans choice
Isn’t the 80 a nightmare to install
Old Sep 29, 2019 | 04:05 PM
Re: Trans choice
I've checked a few swaps on the boards. I'm not saying it's a drop straight in thing but neither is dropping in a th400 that the car wasn't designed around. Quite a few years ago Pocket fabbed one in. Post #467 or so https://www.thirdgen.org/forums/ltx-...t-left-10.html
also https://www.thirdgen.org/forums/tran...l80e-swap.html
I mean you want a street strip 500hp. If you can live without an overdrive then you could compromise to a th400. If you can't then you may want to compromise 500hp or the strip part. 4l80e is more work but you will likely have the most happiness with it done. Hopefully you'll find what works best for you.
asmoboba
Members Firebirds
27
Jul 2, 2015 01:24 AM
