Unexpected wire in pin 41 - LS1 / T56 swap
Old Apr 23, 2020 | 06:22 AM
xWildxChildx's Avatar
All pinouts I have show that there should not be a wire in pin 41 (blue). (I was under the impression I had a 99 year pcm and engine/t56) so far all of the wiring appears to check out, as I am planning my harness build. However I was surprised to find this additional wire, where all pinouts suggest "not used" as in there shouldn't be anything there.
Anyone have a clue why this is here? I plan to trace this as the harness comes apart, just curious if someone knows whats going on here. My guess is a ground.
Also, the hardware number on the PCM is 16220610, which I believe is a 99-00.
Old Apr 28, 2020 | 06:28 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Re: Unexpected wire in pin 41 - LS1 / T56 swap
This Corvette pinout https://ls1tech.com/forums/stereo-el...u-pinouts.html says 41 - PURPLE - HO2S Signal High Bank 2 Sensor 2
maybe compare against 65 where it's supposed to be on the Firebird ECM ?
Old Apr 28, 2020 | 07:17 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
My 99 service manual shows Blue 41 the EGR sensor ground
Old Jun 6, 2020 | 10:10 PM
IrocJason's Avatar
Car: 1986 Iroc Camaro
Engine: 5.3 ltr
Axle/Gears: moser 9in, 4.56gear
I attached a factory pin out for your connector. Appears to be related to the egr system
File Type: pdf
jtmiller92
LSX and LTX Parts
Nov 3, 2017 08:23 AM
BrianI
Jul 8, 2016 01:07 PM
87camaro87
LSX and LTX Parts
Jan 10, 2014 11:52 AM
513camarors91
Nov 8, 2012 03:57 PM
ls2 dude
Feb 22, 2008 02:57 AM
