HEAD STUDS - LS Block - Torque Specs ???
Car: 1989 Camaro IROC Z
Engine: 383, soon to be an LS Stroker
Transmission: 700R4 - Switching to 4L80E
Axle/Gears: 10-Bolt/3.42 will be Moser 12-Bolt
QUESTION . . . When using Head Studs on an LS block ( iron LQ4, in this case ), instead of Bolts, what is the correct Torque Spec, since Head Studs don't "Torque To Yield" ?
Thanks, in advance !
Re: HEAD STUDS - LS Block - Torque Specs ???
If they are ARP, then they will come with instructions or you can also download them from the internet.
GD
GD
I'm not worried about installing the studs into the block, but I am concerned about getting the correct torque spec using nuts, rather than bolts, on the heads themselves..
I think I'll give ARP a call tomorrow and see what I can find out.
Thanks !
Car: '89 Firebird
Engine: 7.0L
Excellent . . . Exactly what I was looking for !
Many Thanks !
