Upshift Indicator LT1 Swap
Old Apr 28, 2021 | 10:48 PM
Cris92RS's Avatar
Car: 92’ Camaro
I’m doing an LT1 swap I just want to know if I’m still going to keep that cool little feature of being told when to shift up by my 92 cluster even with the swap?
Old Apr 30, 2021 | 07:28 PM
LT1/TA's Avatar
Car: 88 Sport Coupe
Axle/Gears: 4.56
Re: Upshift Indicator LT1 Swap
I am pretty sure that it cannot be used,the only indicator for the LT1/T56 f-bodies was the skip shift indicator.
I thought it would be cool if it worked also.
Old May 5, 2021 | 08:08 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
You could get a aftermarket shift light and wire it to trigger the original indicator if you really wanted to.
Old May 8, 2021 | 08:37 AM
Cris92RS's Avatar
Car: 92’ Camaro
You’re a smart man. Thank you much.
Old May 8, 2021 | 09:27 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
I've never had one, but does the stock light operate at normal RPMs, or only at Peak Power?
Most shift lights are there to prompt you to shift at Peak Power.
Other cars I've seen with upshift indicators usually do so where it is best for fuel economy, usually pretty low.
Right now my "shift" indicator is when I bang off the 7200rpm limiter in the GTA and say "Oh Shift!"
Old May 8, 2021 | 10:53 AM
Cris92RS's Avatar
Car: 92’ Camaro
From the quick research I did just now, they are adjustable so you can program it to turn on at whatever rpm you’d like.
Old May 8, 2021 | 11:08 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
You seriously obey that light?
Old May 8, 2021 | 01:43 PM
dixiebandit69's Avatar
Car: '89 Firebird Formula
Engine: TBI 305
Axle/Gears: 10-bolt, 3.42s, Torsen diff.
That light annoyed the **** out of me on my Firebird; I ended up taking the bulb out of the socket.
Old May 19, 2021 | 09:59 PM
Cris92RS's Avatar
Car: 92’ Camaro
I don’t even obey the law my friend let alone that light. I just like it just cause it’s a feature that came with the car idk
Old May 26, 2021 | 08:13 PM
Engine: 2005 LQ4
Axle/Gears: 3:54
On myprevious car i wired in the autometer shift light into the stock light but the more i started racing..i dont look down enough to see it and in the present car i used the bigger light to see it during a bring day at the track
Old May 29, 2021 | 10:47 PM
vorteciroc's Avatar
Top Answer: 1
Lmao!
I could imagine this driving you crazy!
Old May 29, 2021 | 10:48 PM
vorteciroc's Avatar
Top Answer: 1
I went with the "replace the cigarette lighter with a shift-light" modification, myself.
3rdgen92maro
Jul 14, 2006 11:38 AM
nesqwick_05
Mar 2, 2006 10:03 AM
