LQ4 AD244 alternator upgrade
Old May 18, 2021 | 08:50 AM
Kingsnake's Avatar
Car: 1989 Firebird GTA
Engine: 6.0 Vortec
Transmission: LT1 style T56
Axle/Gears: 3:20
Hello,
I have a LQ4 with f-body accessories in my 89 GTA. I am planning on installing a big stereo system that is going to need ~150amps at idle. The stock ~2001 F-body CS130D alternator fits nicely in the lower left position on my car but I really need an AD244 alternator. I understand that this fits in the stock bracket with no issues... Has anyone with this same setup managed to fit a AD244 in the lower left position without modifying the K-member? I guess my other option would to be to install a dual alternator setup with a second one in the upper right position... But that would kind of screw up the clean look I have going...
THanks,
Derek
Old May 24, 2021 | 08:58 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: LQ4 AD244 alternator upgrade
i have that on my 6.0 with a lower dirty dingo bracket. i think i couldn't use the rear support though
Old May 25, 2021 | 02:18 PM
dixiebandit69's Avatar
Car: '89 Firebird Formula
Engine: TBI 305
Axle/Gears: 10-bolt, 3.42s, Torsen diff.
Originally Posted by Kingsnake
Hello,
THanks,
Derek
This is a fairly common upgrade in the 4th gen F-Body community.
I cannot attest to the clearance on a swapped Third gen, though.
Old May 26, 2021 | 07:12 PM
vorteciroc's Avatar
Top Answer: 1
Generally the Body of the Delco "44" series Alternators (CS144, AD244, DR44) do not fit 3rd-Gen F-Bodies, when positioned in a "lower" Mount...
Due to hitting the Stock Engine Crossmember.
Most of the Alternator Brackets that I have tested do not fit at all... or fit terribly.
"Mid" Mount, and "high" Mount brackets do fit.
Otherwise, you could try the "low" Mount setup with an aftermarket tubular Crossmember.
Make sure the Alternator that you purchase includes a test-sheet with the potential output at different RPM (Alternator RPM).
Then make certain that the Alternator will supply enough amperage under load at the (Engine) Idle RPM/ cruising RPM.
Many alternators that are rated at a decently high output... are NOT capable of doing so at an idle/ low Engine RPM.
For example... My 3rd-Gen has Holley EFI with 8 ignition coils that can add-up to 40 Amps, dual electric Radiator Fans, dual electric Fuel Pumps, Transmission oil-cooler electric Fan, Engine oil-cooler electric Fan, air to water Intercooler coolant Pump, Nitrous-Oxide Bottle-Heater, ETC...
Since the car has all it's Lights working, windshield wipers, power windows and locks, Heat/ a Blower-Motor and a Radio...
As well as all the stuff that I added to the car in the paragraph above.
I needed an Alternator that could reliably handle a 150A-180A Load at an idle.
So I had to purchase a 350A rated Alternator. I purchased a 4-Wire Aftermarket Delco AD244 that is good for about 200A when the Engine is at an idle...
And about 350A as the maximum output.
Old May 26, 2021 | 08:09 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Truck alternator in stock location/bracket without the rear support brace,removed the triangular support bracket to the kmember for clearance.Many have done this before and use the same belt.I did this upgrade yrs ago when the orignal fbody alt died and I wanted more amperage.
Old May 27, 2021 | 06:04 PM
vorteciroc's Avatar
Top Answer: 1
Yes, the Mid-mount and High-mount fit nicely.
Rob D
Sep 23, 2009 01:36 PM
ThraxXx
Aug 16, 2005 09:29 PM
necrophile
Nov 9, 2000 07:27 AM
Artic White Z
Nov 4, 2000 10:29 AM
