A/C compressor clearance
Old Jun 23, 2021 | 05:44 PM
rearview's Avatar
Car: 1990 LS6 Camaro
Engine: LS6 with a cam basically
Axle/Gears: 4th gen 3.42 rear
I thought I'd read that the A/C compressor on an LS1 from an F-body (a 2000 in my case) was mounted in a different position than on a truck engine. Does one still have to notch the crossmember with an f-body sourced LS1? (or high-mount it?)
I'm acquiring parts and planning an LS1 swap into a 92 Camaro if that's important. A/C is definitely important!
Thanks guys, I'm sure I'll have a lot of questions in this upcoming process!
Old Jun 23, 2021 | 06:17 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: A/C compressor clearance
All the AC compressors are in the same general location. All of them need notching of the k-member to live in that location. There are small differences in how far fore/aft the compressor sits and how it effects pulley positioning.
Old Jun 23, 2021 | 07:00 PM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
Yes k member needs notching but all is well hawks makes a notch kit that makes it super easy to do. Also if using an fbody oil pan may need to notch 1/2 in on back of k member. Its easier to do before engine is in.
Old Jun 23, 2021 | 07:13 PM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44 IRS, Tru Trac, 3:73 gears
Dirty Dingo offers a kit with a Sunden SD7 compressor and brackets that move the compressor up and closer to the engine. The brackets can be used on all three front accessories configurations. It also replaces the variable pressure compressor that most LS engines use with a constant pressure compressor with clutch which is easier to adapt to older or aftermarket systems. This car has a custom k-member, but it still shows how much more clearance the kit provides.
87camaro87
LSX and LTX Parts
Nov 5, 2014 02:04 PM
jimmy92rs
Jul 20, 2012 01:58 PM
Aviator857
Jul 26, 2007 09:24 PM
91TAL98
Dec 24, 2006 07:52 PM
