running a/c after ls1 swap
Car: 1992 RS
Engine: 01' LS1
Axle/Gears: 10 bolt auburn pro posi, 4.10 gears
So I just completed a ls1/t56 swap in my 92 rs. I decide that I want to put in the a/c system. So I installed LS1 a/c compressor and bracket last night. When turning to the left the idler arm on the steering linkage hits the compressor. I lowered the idler arm as low as possible on frame and it still hits. Any ideas to make work?
Car: 1992 RS
Engine: 01' LS1
Re: running a/c after ls1 swap
anyone run into this problem? steering linkage hitting a/c compressor?
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
Cant remember who's car or thread, but they were able to dremel down the ridge on the AC compressor to gain enough clearance.
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Car: 1992 RS
Engine: 01' LS1
Car: 1992 RS
Engine: 01' LS1
Car: 1992 RS
Engine: 01' LS1
i have a spohn tubular kmember and the mounts have about 40k on them
Car: 93 240SX
Engine: LQ9
Car: 91 Firebird
Engine: 6.0
Car: 93 240SX
Engine: LQ9
Engine: Cammed 6.0L LSX
We had the issue with my dad's '89 IROC-Z with an LS1 swap and a/c. We took the idler arm off and I believe our fix was slotting the holes on it so we could adjust it more than before. That seemed to be the trick for us. Good luck!
Car: 1992 RS
Engine: 01' LS1
thanks ill try enlongating the holes to get more adjustment first, if not then ill dremel the compressor for clearance.
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
All this talk about moving the idler arm, doesn't it have to be horizontal with the ground in order for it to work properly? I know when I rebuilt my front end last year, I spend a lot of time getting it perfect. Either way, Jimmy, I cant wait to see the car!
BikeFarm
Aug 11, 2015 11:35 PM
db057
Aug 11, 2015 10:11 PM
